Originally Posted by 1DogRescuer
Thanks. NET Inside Diameter is not a spec that is part of standard spec nomenclature.
Absolutely correct so why you're seeking non-standard dimensions eludes me---he who initiated and has performed this upgrade/modification.
The 16" steel wheels that were OEM to the E-Series fit, most likely the Alcoa's as well IF they were spec'd for the 2008 and later year E-Series up through the E350 chassis; E450 wheels might fit but I can't be sure.
What year and type is this drop off donor you're working with? As for this "generation" craziness better to stick with specific years and chassis GVW.
For me since you're deviating from what I've already posted I'll have to leave you to your own discoveries or trial & error work---I won't comment or speculate on something I've not done myself.
Best of luck with this!
