Originally Posted by carringb
Have you checked the spark plug yet? A spark plug backing out makes a pretty good tick too! The #10 is also the most likely to do it I've found out. On mine, it would loosen up after spending extended time (like 10s of minutes) above 5k RPM. So something to do with harmonics.
You can probably get enough access by pulling the motor mounts and letting it drop down, in conjunction with pulling the intake manifold.
But FWIW.... reman V10s are relatively cheap (you can buy 4 for the price of one high-pressure fuel-pump job on a 6.7L PSD), and swapping one is only a little more labor then tearing into one of the heads.
I did when I first noticed the ticking but before I dig in I will re-check.
Ive owned 5 or 6 of these ford modular motors and never had a plug back out, Ive always added a very tiny film of anti-seize and torque them more than they call for and never had an issue.... but I think this may be one of the only ones that only has the 4 threads in the heads so its possible I guess but when poking around with stethoscope It didnt seem to come from any plug bores but would be great if thats all it was lol. (my luck is never that good)
