Old 11-18-2019, 08:07 AM   #11
Originally Posted by Jwally2 View Post
Sorry for the slight highjack; is fluctuation between 47.5 to 48 volts to the FICM acceptable, or should I start to worry.
Totally fine. It's when voltage starts slipping lower like 45V or even lower that will toast your injectors.
2011 VW TDI Golf for hwy fun
Old 11-19-2019, 09:27 AM   #12
darkstar66's Avatar
Thanks everyone. It was indeed the FCIM. Voltage was at about 29v. Check wires, harnesses, battery connections, fuses etc while we were in there. I shopped it pretty hard but eventually talked with enough people that I felt comfortable taking it to EIS Diesel in PDX. Felt very good about my experience. Guatemala here I come!
darkstar66 is offline   Reply With Quote
Old 11-19-2019, 10:32 AM   #13
Whoa. 29V is very low. I would be surprised if that didn't damage the injectors. I'd recommend monitoring injector duty cycle under high load, and also cylinder contribution (aka cylinder balance).
