Old 11-29-2024, 01:20 PM   #1
Ford E4OD cooler lines.
My 93 E250 Sportsmobile factory fitted with the E4OD trans has a problem with the factory cooler lines that have cracked due to age and vibration. I have them patched with pressure hose for now, but I want to replace the lines with braided stainless steel.
Can anyone recocmmend where I can get pre terminated braided stainless steel trans cooler lines for this application?
93 E250 4.9L E4OD trans?
'93 Ford E250 "Canela" RB11 Penthouse top 4.9L EFI Restoration / modernization in progress.
dbhosttexas is offline   Reply With Quote
Old 11-30-2024, 09:51 AM   #2
You wont find an off-the-shelf solution. You will need to either DIY using AN fittings or have a hydraulic shop make you what you need.
If these are the factory rubber lines, replace them with some quality Dayco hoses or similar and get back to gettin. The last set lasted 31 years.
Big_ern_101 is offline   Reply With Quote
Old 11-30-2024, 06:19 PM   #3
They are actually hard lines, not rubber lines. I have seen this with Fords before and I do NOT like it... There is a marine / hydraulic shop by the docks here that might be able to fab me something up...
Old 11-30-2024, 10:56 PM   #4
larrie's Avatar
Not the same hoses but I had my mechanic pull the front rubber break lines and take them to a local hydraulic shop to have replacement made from braided stainless steel. He gave them the rubber ones so to make sure that they could match the fittings. I would have done it myself but the shop did not do walk in retail work.
Larrie
Old 12-01-2024, 09:21 AM   #5
If you wish to remake the hard lines, same story, DIY job or local shop.
Me? I would remake the hard lines as-intended and not soft lines for the whole duration. I just dont trust AN lines or hydraulic lines as much as I trust hard piping, spent enough time replacing them on old equipment. The rigid metal lines were always the last to go.
Get yourself a roll of tubing the diameter you need, a tubing straightener, a bender, a flaring tool, a case of High Life, and an open Saturday and have at it. If you can get the old lines out in one piece, I have found that you can usually bend something up pretty close to them in free air, install, tweak as needed. Very fun, rewarding process.
Old 12-01-2024, 03:36 PM   #6
Try this, https://www.jegs.com/i/JEGS/555/6309...CABEgKaUfD_BwE
Or, https://4lifetimelines.com/collectio...7nTxt_N7DAn2rm
There are lots of other options too, search Google
Goldiebeast
postandbeam
Esme
Amy V
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
