Old 05-23-2023, 12:46 PM   #1
vandiesel's Avatar
Help! Engine won’t turn off
I’m on my way to Moab in e350 6.0. Stopped for lunch 100 miles out of Ogden with a full tank for lunch. Engine turned off but ignition did not. I heard electric vacuum pump running and went to turn off ignition and on. Engine started and would not turn off. Key comes out. Starter won’t engage. Good news it’s running and I’ve eaten. Has anyone had this happen and do I need a locksmith or dealer?
Old 05-23-2023, 01:28 PM   #2
Is it still running? Or were you able to get it to shut off?
Sounds like ignition has a broken return spring, or maybe the keyway stripped out.. It’s not too hard to change the entire ignition.. You can also remove the ignition cylinder and try to rotate the ignition internals with a flathead screwdriver. Basically, turn the key to ON, find the hole in the bottom of the column shroud, and stick something skinny in the hole like a long #1 Philips screwdriver. Or a mechanic’s pick. Push hard and that should release the cylinder allowing you to pull it out. This is step one for the ignition replacement as well, except to replace the ignition the shroud needs to come all the way off.
Old 05-23-2023, 03:36 PM   #3
vandiesel's Avatar
I’m at the Ford dealer and I remove the ignition. I also removed the switch down below on the column. The linkage in the ignition cylinder are working fine. If I move the rod on the ignition switch down below in any positions it doesn’t turn the rig off, nor does it change anything. On top of that my turbo has begin to stick, so I’ve lost power.
Old 05-23-2023, 03:44 PM   #4
Am so very sorry for your issues ! Surely the Ford dealer has the answer !? Good luck !
Old 05-23-2023, 04:27 PM   #5
vandiesel's Avatar
Lost an injector. Leaving the van
Old 05-23-2023, 04:44 PM   #6
That’s not good. With the ignition functioning, and losing an injector, I’m suspecting a melted wire harness now…. Fingers crossed it’s those 2 faults are just coincidental though!
Old 05-23-2023, 05:55 PM   #7
bigriver's Avatar
ooof.. tough day pard. Hang in and keep us posted.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 05-26-2023, 09:13 AM   #8
vandiesel's Avatar
Update. Dealer says no compression on cylinder 8, no blow by and valve train looks fine from above. They also don’t think it’s the bottom end. What gives. I need to get it home from SLC. Motor built to the hilt by Orange County
Old 05-26-2023, 10:24 AM   #9
vandiesel's Avatar
Can anyone recommend a custom shop to swap godzilla motor with 10speed into my van? Need a capable custom builder.
Old 05-26-2023, 10:44 AM   #10
Tough day we all feel your pain! Maybe you could coax MG to do it? He is close to you and there is nobody more qualified/capable. https://expovans.com/about-us/
clicker44 is offline   Reply With Quote
