How can a egr deleted 6.0 throw a p0403 code?
I have a 2006 6.0 EGR delete that has been running beautifully. This morning I started her and she ran rough for about 30 seconds, then smoothed out. The CEL came on so checked codes and there was a p0403 which points to the egr solenoid or an electrical problem with the egr system. With the egr deleted, why would I get an egr problem? The symptom also matches what a p0403 code describes. Is the solenoid still active with the egr deleted, starving a starting engine of oxygen? So what would be the best procedure to track down the rough start and p0403 code? Thanks!
Tony
2006 Baja Tan SMB 4X4 RB50 PH 6LPSD
Photographer in Belize, Central America https://tonyrath.com
