Canyon Sportster: Although there is much discussion of a fuel pump inlet screen, no one has posted a picture of it. So I am doubtful that it exists.* The injectors don't have screens.
So that leaves only the screens in the tank (which should be removed during the Hutch Mod) and the original equipment manufacturer's (OEM) fuel/water separator filter in the valley between the valve covers.
Yes, there is a high pressure pump (the HPOP), and it does have a small screen, but it does not pressure fuel, rather it pressurizes oil. The 7.3L is not a common fuel rail system. The 7.3L is a HEUI system ("Hydraulically Actuated Electronically Controlled Unit Injector") in which each injector is responsible for pressurizing and atomizing the fuel for its cylinder only. Each injector does this by a plunger much like in a medical syringe. The high pressure pump (HPOP) merely pressurizes the oil which, when the armature on the injector is electrically activated, opens a valve to let the oil rush in to push the plunger down to shoot the fuel out the seven very very very small nozzle holes, thus atomizing the fuel to be burned, into the cylinder.
I can't find the cutaway of the injector itself, but here is a cutaway of an injector in its cylinder showing the electric actuator/solenoid on top, the fuel and oil galleys in the cylinder head, and the injector's dedicated glowplug to the right:
For my van, I frequent this Sportsmobileforum.com and the 7.3L subforum at ford-trucks.com
Your English is very good and the members of the 7.3L forum are great, so, since I don't know one tenth of what they know, I strongly suggest that you join the ford-trucks.com forum for free and post your question as written.
The Brotherhood will then answer your question and it will help you, me and many others understand our engines better.
1999 - 2003 7.3L Power Stroke Diesel
http://www.ford-trucks.com/forums/forum31/
* Edit: There really is a pump inlet screen!
http://www.ford-trucks.com/forums/12785 ... st13766613
