Originally Posted by FCAshevlle
Lots of threads on this topic so I apologize if it's been beat to death. Just jumping into SMBs w/ Margot, our 2012 E150. When shopping around I was convinced I needed a LSD axle, but grabbed this van for the low miles and price despite it having an open Dana 60/3.73. Was planning on adding a diff down the road.
However, when I honestly think about the usage I'm not sure a diff is money well spent. We will be 90% (at least) pavement with almost all dirt being maintained roads to trail heads. I used to own a 77 VW Westy and drove that thing over all the same roads with zero issues. I also had an Xterra for a while doing all the same things. The 4WD was fun but never needed. People drive Prius's on most of the dirt roads around here ;-)
I'm starting to think spending money on all terrain tires and at least a rear sway bar would be better at this moment.
We went through quite a few "off road" places around Moab and San Juan Mtns area. 2wd, open diff, and 32" BFG A/T tires. A limited slip would be very nice but we didn't have the time or money to get one. My plan was to find a factory 4.10 axle from an ambulance that had a factory LSD.
We have decided to go 4wd so going though the LSD/regear issue again. This is for 2 axles but I was quoted $3300 to regear front and rear and add a Truetrac in the rear. Split labor in half and add to the Truetrac then it would be $1200 for them to just to install the rear limited slip.
I would either looked for a used rear axle if you are running bigger tires and need both the LSD and lower gearing or do like was said above and just invest in some decent tires and maybe some traction boards.
