Old 04-24-2015, 11:55 PM   #11
ArikB's Avatar
Re: Oil filter?
Originally Posted by JoeH
Originally Posted by ArikB
I was referring to buying the newer pan and switching to an internal filter but yes that is the external filter. It can be found for much cheaper here: http://www.dieselfiltersonline.com/ford ... issio.html
Good source for all your filters. The diesel fuel filters alone are ~$50 cheaper than the dealer and they are motorcraft and not aftermarket.
Thanks!
You have been very helpful and I appreciate your input!
2005 Quigley E-350SD 6.0L
ArikB is offline   Reply With Quote
Old 04-25-2015, 10:17 AM   #12
Re: Oil filter?
adding a trans filter is a great idea and certainly better than stock due to larger size filter area. I added one when doing my trans/fan cooler.
carl
2010 SMB
