Old 01-06-2020, 10:08 PM   #121
allenl's Avatar
great thread, thanks for all the info. I’d be curious, did you get the in and out temps yet?
allenl is offline   Reply With Quote
Old 01-07-2020, 05:31 AM   #122
bet on black's Avatar
Originally Posted by Lilnuts2 View Post
It's my understanding the vans have a Turbo one step bigger than the pickups and the pickups come with an intercooler from the factory so I'm not sure if that is the issue.
Van turbo has a larger turbine hissing but a much smaller compressor housing. I swapped to a truck turbo on mine.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 01-07-2020, 05:33 AM   #123
It's because the truck turbos are smaller, hence better low end.
https://www.powerstrokenation.com/fo...s/78471?page=1
Just the van turbine is larger, so it spools at a much higher rpm. The compressor side is actually smaller.
LiamMobile
Shyll
Beatrice
Drizzt
