As soon as it got cold and dry my right rear leaf spring has developed a squeek. It is at low speeds and happens on lightly bumpy movements. When I rock the van and listen it sounds like it is coming from the forward spring mount. Worn out? Needs lube? What?
It sounds like our van but ours squeaks from both the front and the back. I think ours is from the rubber body mounts...there are, I think, two pairs in the front and two pairs in the back. I occasionally spray them with a silicon lube which helps but the squeaks eventually come back.
Jack
'01 Ford EB50p Quigley 4WD
The spring bolt collar and bushing can shift and leave the spring against the mount instead of centered- the squeek can come from metal on metal of spring and mount.
