Originally Posted by carringb
KTMRIDER - Look at your owners manual. It warns specifically against installing a tub/fin cooler, because the pressure drop introduced can damage the transmission.
carringb,
I put in a call to the shop and asked them to check into this. Their initial response was that this was the cooler recommended by the people they ordered from. Don't know if this was from a catalog or a horse's mouth but all the specs were given by the shop when ordering. Not that what you are saying isn't true I just need somewhere to point the shop.
Also, finally just read through all the manuals that came with my van and see no mention of the warning on using a tube and fin cooler. I have the 2000 7.3 E350 EB with the 4R100 tranny and stock towing package. Are you sure this is true with the 4R100?
Did look online and found a few mentions of not using a tube and fin with overdrive trannies but it was so generic I can't go just by that blanket statement. Can you point me to a reputable source or document on this topic for proof that I can take back to the shop for more research?
Thanks for your input on this, appreciate it.
Eric
