Hey Guys,
Been a long time since I posted and I'm about to pull the trigger on major surgery on my "baby". Take a quick look and I would appreciate some feedback. Btw, I'm looking to pull a 24-26' Boat eventually so I'm looking to keep my temps down, have reliability, and a bit more performance. Is this Overkill especially on the Aluminum heads, Overhaul kit, and new Turbo.
What's already been done:
1. BPF FICM
2. BPF Water cooler & New Thermostat
3. Aluminum radiator
4. Switch override for Manual Fan Clutch
5. Bluespring Mod
6. New Exhaust
7. Magtec Transmission Pan
8. FICM Tune/Atlas Tune
9. XDP Extreme Starter
10. Replaced Vacuum Brake Pump(3 years ago)
What's next TO BE DONE:
1. 6.0L Powerstroke Upgraded STC Fitting, IPR valve kit
2. 6.0L Powerstroke Glow Plug Kit
3. 5R110W Powerstroke Transmission Saver Plug
https://www.accuratediesel.com/shop/273.html
4. IPR valve
5. ICP CONNECTOR
6. ICP SENSOR
7. Ford High Pressure Oil Pump Filter Screen
8. ProSource Diesel Updated Engine Oil Stand Pipe + Dummy Plug Kit
9. Turbo Oil Feed Tube, Ford 6.0L Diesel
10. BPD EGR cooler
11. Ford OEM Oil Cooler or BPD Oil Cooler
12. 6.0L Powerstroke Diesel ALUMINUM O-ringed Cylinder Heads DX SERIES
https://dynamicdiesel60.com/product/...ads-dx-series/
13. 6.0L Powerstroke Diesel Over Haul Kit Stage 1
https://dynamicdiesel60.com/product/...l-kit-stage-1/
14. Engine Wiring Harness
15. Ficm Wiring harness
16. arp studs
17. Engine Block - Machining
18. New Titan Turbo
https://dynamicdiesel60.com/product/...l-powerstroke/
19. Tru-Cool Max.
https://trucool.com/products/tru-cool-max
20. Steering Box
https://redheadsteeringgears.com/pro...steering-gear/
21. Replace Tensioner
22. Replace Pullies
23 Heavy duty Alternator
https://dynamicdiesel60.com/product/...ternator-8478/
