'03 E350 Sportsmobile heater not working
Front A/C works and all of the vacuum controlled "motors" and blower fan work but the heater "temperature blend door" will not open when the settings are on for hot air.
This assembly is located under the dash on the passenger side of the van just above the passenger's feet. I've removed the heater core cover. The heater core is exposed. It is not clogged with dirt or debris. I can also see the "temperature blend door" in the center and a vacuum controlled "motor" on the right side of the heater core housing.
Everything but the "temperature blend door" works. I can pull the "blend door" open about a 1/2 inch with my fingers but it snaps closed when I let go. I can also see the "vacuum motor" and the rod on the right side of the housing. The "motor" works when I turn the dial to OFF. There is little room for me to see the mechanism that opens and closes the "blend door" but nothing feels like the arm or rod are lose.
I want to avoid pulling the heater core. Any suggestions appreciated.
