97' RB30, The leg on the rear of my bed stands pretty much straight.
The leg in the front is very slanted. I can put it back into place, but after a few sleeps it sticks out again. Leg hardware looks like it's riveted. Is there an adjustment I can do to keep that leg straight? I'm afraid it will snap and break.
I'd look at putting a steel sleeve just long enough to fill the gap on the threads/length yet leave enough room for the leg to pivot as needed - tight yet loose enough to pivot -
...as we say in the engineering world....... What's good look like? Can you post a few close-ups of a good leg? ..and maybe a few more close up angles of the bad leg? The problem should be pretty obvious.
