Biggest issue will be the cluster. Your cluster uses a completely different architecture than the newer vans, so you can't just swap the new cluster in. And the clusters are not the same shape. You'll have to either trim your existing cluster to fit, cut a custom panel and use universal gauges from somebody like VDO or AutoMeter, or have a full custom cluster built by Dakota Digital.
Fortunately the HVAC controls are common all the back to '92.
