Old 06-16-2022, 10:00 PM   #11
aarcaris's Avatar
If you are looking for a super stout water fill I would look at Aquor. I used two of these on my build one for the water fill and one for the rear shower and they are great! They are a little pricey but they are very high quality.
Vandit - 2013 E250 Ground Up Build
aarcaris is offline   Reply With Quote
Old 06-17-2022, 04:42 AM   #12
Agree, Very clean look.
Old 06-17-2022, 06:19 AM   #13
Good suggestion, I’ve had my eye on these. Maybe one of you can answer a question I had. For the angled quick connector, can it be connected either way? Meaning the angled portion facing up or down. Reason I was wondering is if I ever needed to fill my tank in a gravity feed scenario, it’d be easier if the inlet elbow was pointing up (I think). I do plan on filling off my hose bib at home 99% of the time.
Also, just noticed Amazon has most of the Aquor lineup available for Prime delivery. Easy to get and return if needed, fyi.
ibike is offline   Reply With Quote
Old 06-17-2022, 08:03 AM   #14
aarcaris's Avatar
I can check on mine later today to confirm but I am pretty sure you can connect it so it's clocked either up, right, down, or left.
Another plus for adding an inspection hatch is it's a convenient way to have a second fill for things like water jugs or other means that won't attach to a hose.
Old 06-17-2022, 08:04 AM   #15
Sure, it can point upward. Ordering directly from them was easy and quick, I personally wouldn't give amazon a piece of the pie.
Old 06-17-2022, 08:13 AM   #16
aarcaris's Avatar
I also ordered directly from them and they shipped quickly. Plus I chatted with someone from their company before ordering because I had some questions and they ended up giving me a discount code making it cheaper than from Amazon. Though Amazon does make returns easily so I can see the appeal.
Old 06-17-2022, 08:35 AM   #17
Also if your inlet area is tight the make a 1/2″ PEX Crimp Inlet, 90° Elbow. It replaces the standard 1/2" female NPT inlet.
Old 06-17-2022, 11:57 AM   #18
Fantastic, thanks everyone. I think Aquor is the answer. I was looking at some quick disconnect fittings from Colder Products but was having a hard time finding all the fittings that match.
Old 06-17-2022, 06:55 PM   #19
velo47's Avatar
For reference, here's the deck plate I installed in my water tank. I used plenty of silicone, just in case.
All that grunge is on the outside of the tank, not the inside!
W3TAX
WRDZ686
2016 4wd 144" Sportsmobile Sprinter
2019 Chevy Colorado ZR2
2002 lifted & armored WRX wagon (sold)
velo47 is offline   Reply With Quote
Silver Streak
Glider
Esme
Amy V
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
