If you got similar actuators and built a easy up system like ccv uses for their tops you could easily raise it up 3-4’. You’d have to have the portion that raised up narrow enough that it could raise up into the pop top area. Then when in a lower mode it would nest into a spot where your bed was full width again. If the weather was nice you could nap upstairs where airflow is better.
