Old 10-08-2021, 02:49 PM   #11
Twoxentrix's Avatar
ebrogie pic's with this message:
"I have no voltage across this device, this is in the back of my
Sportsmobile near the DC control center. I’m not sure what it does or
what we call it?"
Old 10-08-2021, 03:14 PM   #12
So that is a surepower separator. You should not really look for voltage across the device. The top post (in the picture) should be starting battery. The bottom terminal should be the house battery.
Check for voltage on the bottom side, if you don't have there, one of those three wires goes to the battery. Get a better shot of what that larger wirer is connected to.
If you have voltage there, track the wires to the fuse box, you should run into another circuit breaker like the one on the starcool panel (top left). In fact one of those wires probably goes there. It is possible that has finally tripped, should be a button to reset.
Please give more info on the electrical equipment in the van.
Old 10-08-2021, 03:35 PM   #13
FYI, both of those terminals are battery positive, and to measure voltage you need to reference the negative lead of your meter to ground, thats to say, connect it to a ground source and the positive lead to which ever wire your checking voltage on.
Old 10-08-2021, 03:45 PM   #14
Twoxentrix's Avatar
Sorry, Forgot to include this portion of the question ebrogie sent me:
"I am wondering why I have no voltage across this. I have 12 v voltage at the rear of the proSine ll. No voltage at the top master circuit breaker. And no voltage at the top of the device in the photos "
Old 10-08-2021, 04:26 PM   #15
This is what I see.
[IMG][/IMG]
As Artic said you won't see 12 volts across the Separator Terminals. You need to measure from ground to the each of those terminals.
Old 10-08-2021, 05:49 PM   #16
Originally Posted by 1der View Post
attaching image/file:
https://www.sportsmobileforum.com/fo...l&titlesonly=0
where are you located?? Nebraska (northeast)
sportsmobile or diy or ?? 06 6.0 sportsmobile made in calf
house battery location (s)?
house battery is in cradel behind rear axel i put in a agm a year ago
ebrogie is offline   Reply With Quote
Old 10-08-2021, 07:29 PM   #17
REF
REF's Avatar
Send a message via MSN to REF
So did yanking your Edge tuner resolve these issues?
Old 10-09-2021, 10:51 AM   #18
Originally Posted by Twoxentrix View Post
Odd, I have never heard a whine on either Espar units, I do occasionally here a clicking sound that comes from the fuel pump when it’s pulling fuel up from the tank.
Will file this in the back of my mind; At least now if I ever hear a whine I know where it’s likely coming from.
Yep some hate that clicking sound. My Hydronic water pump is what I suspect makes the noise. It also makes the same noise while shutting down and just figure it keeps coolant flowing as it cools. All I hear from the Airtronic is the fan blowing but with low voltage it will do the same; start for a minute, the fan ramps up and if it fails, then the fan makes a slight spin down noise.
To the OP, on my 2006 there is also a ground strip worth looking at. Mine is in the rear passenger wheel well area. But I'd still suspect you have a issue with a positive connection somewhere. There is also a high amp lug located close to the separator where my inverter connects to. I'd check that connection as well provided your build is similar. That's one of the problems...many builds are different. If you see any green on any connections, it can indicate a corrosion issue. Hope you find the issue.
Old 10-09-2021, 02:47 PM   #19
When I unplugged shore power there was a clicking by the control center every 30 sec of so then I plugged in shore-power and the charging of house battery state and slicking stopped
Old 10-09-2021, 02:53 PM   #20
I took more pictures of my 06 E350 set-up Scalf77 labeled one and that is where i started Pulled all fuses in these pictures all were ok Have not found another reset circuit breaker
https://www.sportsmobileforum.com/fo...lbums1545.html
Vanna
gahamby
Ann the Van
Bongo
