Originally Posted by ebrogie
does it give a code after so many minutes? Do you have two one for the cabin and one for a water heater?
Yeah I've got two. Water heater works fine. The cabin heater used to take a minute or so to flash a code that was glow plug related. Since I relaced the glow plug the F22 comes up right after the fan does a test spin. This is what I find for that code.
022 Glow plug, output (+), short
circuit after UB (battery voltage) • Check glow plug lead harness for correct laying and damage, if ok —> check
lead harness for continuity, if ok —> replace control box,
