high and low pressure propane setup?
Two notes here-
1- Teflon tape or any sealant is not to be used on those bullet shaped POL fittings. Even the ones with a rubber seal. If they don’t seal with mild torquing with a wrench replace the seal or in the case of the solid brass units replace the brass bullet shaped portion. Sealant is only for fittings that have no built in seal like tapered NPT. Don’t combine the two.
2- My quick disconnect setup is limited to 60 psi. Useless for what it is intended to do when it takes full tank pressure that can exceed 100 psi easily.
Stay safe.
G.
