Old 09-22-2021, 07:12 PM   #1
Bellpilot's Avatar
House water pump access
Hi all, bought a newer SMB 2013 EB 44 with the water tank and water pump under the side sofa. I need to get access to the water pump to repair it. Does anyone know how to remove the seat cushion to get access to the pump? There must be an easy trick to this because the tank drain was behind the tank as well which would be much easier to get to with the bottom cushion removed.
2010 E350 6.0 4x4 EB 50 SMB
Old 09-22-2021, 07:25 PM   #2
My old side mounted gaucho had a nut on each of the front corners. I am not sure on the original size, as I eventually changed them to wing nuts. After removing them the cushion should pull up.
Moby
maptester
Jiminy
Gooseberry
