As some have noted over the years, the Norcold fridge that SMB often installs can be prone to noisy operation. I had one in my 1998 SMB and it was pretty quiet and was still running strong 22 years later when I sold the van. My 2011 has basically the same fridge, which works fine but was pretty loud at night between rattles and vibration, so much so that it sometimes woke me up. I finally had some time this fall to try and figure out a solution. So far the easy mods I made have made a huge difference. Rattles are gone, and vibration is much better. Here’s what I did:
Here’s what the back of the fridge looks like. The compressor (vertical cylinder thing) is mounted directly to the metal body of the fridge. The cooling coils mount to the bracket that holds the compressor to the body. And there’s a small cooling fan mounted at the bottom. The noise begins when the compressor kicks on, creating a sort of harmonic vibration that creates rattles and transfers to the van through the refrigerator cabinet wood.
I figured it would help a lot if I could isolate the various components from each other, and especially from the metal body of the fridge. I first tried using some rubber sheeting I had (actually old MTB tubes), but that didn’t work at all (not thick enough). Then I hit the local hardware store to get some rubber washers and grommets. I installed the washers to both sides of the clips that hold the coil assembly to the mounting bracket. (An extra tip is to make sure the coil mounting screws aren’t too tight, to further reduce the transmission of vibration.) I got thicker rubber grommets to use between the mounting bracket at the refrigerator body itself. Basically trying to isolate any metal to metal contact. Finally, I zip-tied the whole assembly together to reduce vibration even more. End result was a huge improvement in noise for what was a pretty easy mod.
I do still get some vibration transmitted through the refrigerator cabinet itself, which I plan to address in the spring by adding some sort of foam padding to isolate the fridge as a whole from the wood. I’m pretty confident that should do the trick to get it really quiet.
