https://manuals.heartlandowners.org/...11-05-2015.pdf
From the service manual page 32: "Electrode sparking, but gas not coming through burner:
a.Check to see if voltage is coming out of module board
to gas valve after the 12 - 18 second delay. Check the
wires in the molex connector to be sure they are intact
and making contact with the module board. Check wire
from the module board to valve for continuity. Wire and
connections check OK - replace module board.
b.Voltage is coming out of module board to gas valve, but
gas valve does not open - replace gas valve.
