If I'm not mistaken, the front frame of the fridge has 4 screws holing the unit in place, but (so you are aware) it seems several members (myself included) have had additional screws on the outside of the cabinetry that were drilled into the side of the fridge (I have one on each side that goes through the outer cabinet wall into the side of the fridge). Can only assume that was done as additional method to anchor the unit in place for strength. So you may want to check to see if you have these as well in the event it doesn't slide out easily.
