In an effort to determine why Pete's roof goes up/down so easy, Pete sent me one of his helper springs to measure.
I grabbed one of my helper springs (they are no longer used..sitting in a drawer...my solution here:
https://www.sportsmobileforum.com/fo...gs-1084-8.html) ...and measured it as well
Pete's Spring:
1.920" OD
.250" wire dia
11.75" Free length
rate 52 lbs/in
23 active coils
My spring:
1.920 OD
.250 wire diameter
24" free length
rate 20 lbs/in
47 active coils
I ran these springs through an online spring calculator and got spring rates very similar to what I measured on my mill using a digital weight scale.
https://www.newcombspring.com/spring...ing-calculator
Interestingly, the spring calculator shows a max load of around 220 lbs for both springs before the spring starts yielding (takes a permanent set, gets shorter)....assuming the spring material is either hard drawn steel or music wire....a safe bet.
If we assume the above to be correct then for either spring or roof length the max load on the crossbars is 220 lbs x 2 =440 lbs (one each side)
If we blow off the max allowable load assumption above (usually a bad idea) ....then pete's spring is at around 288 lbs at solid height..fully squished...which is about 5.5" of compression.
In that case Pete's springs are exerting 288 lbs x 2 (one each side)= 576 lbs total.
What does all this mean?
Well....in Pete's case with a bare EB top his helper springs are exerting somewhere between 440-576lbs total when the top is down.
In my case, with an RB top and about 70 lbs of solar and yakima crossbars on the roof I'm applying more than double that force (around 600-700 lbs each side) using a custom designed gas spring/die spring setup to get the top to raise easily.
..so another 60-70 lbs on the roof requires a boatload more spring load when fully down to get the roof to lift easily.....if I wasn't so old and lazy I would figure out this relationship...
