04-04-2021, 05:02 PM
#41
Installed my new Truck Fridge two weeks ago (replaced my 21 y/o Norcold) and just got back from a trip to the Oregon Coast last night. The new refrigerator was much quieter than the old and seemed to cycle on/off much less often. To install it, I needed to remove the original SMB 1 1/2” risers. Replaced them with a 1/2” plywood board with routed out relief areas to fit over the existing “L brackets and bolt heads”. The refrigerator’s flange protruded out a bit more than the original so I ended up cutting shallow rabbits along the backs of the cabinet doors. I used to turn off the Norcold at night due to noise and never noticed the new one running.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
04-06-2021, 05:46 PM
#42
Yikes, Jabberbox, that's scary. I'm glad you and pooch are OK.
I can't guess the exact cause, but since you smelled ammonia early in the "event", it seems like a leak in the ammonia line is a strong candidate.
The heater flame needed for absorption fridges has always been a balancing act - the single-pressure absorption mechanism involves a flame and a small amount of hydrogen mixed in with the ammonia, so I'm sure that's perfectly fine... :/
Lord knows if it leaked first, or if you had some excess heat melt insulation in the electrical, which caused a small flame, which then caused the leak...
2003 Chevy Astro 4WD
GTRV Transplant
04-06-2021, 06:18 PM
#43
Gone Traveling
Im just thankful it happend at a time when i was there to put it out and not inside a store or something with the Dog locked inside. I dont care if the truck burns to the ground, but if anything happend to my Dog i would never forgive myself. Now i even worry about the 12 volts batteries, im kicking around installing battery cutoff switches on both the start battery and house batteries so i can kill all the juice if i have to leave the Dog inside unattended to go into a grocery store or something.
04-06-2021, 08:01 PM
#44
That's a bummer. It does happen though. Pretty much everything on an RV is dangerous, just know your enemy. Propane appliances, AC wiring and components that were never really designed to be in a moving (bouncing) vehicle, etc.
Your upgrade to 12v will be worthwhile in many ways except the the price.
04-06-2021, 09:16 PM
#45
Originally Posted by Steve C
Installed my new Truck Fridge two weeks ago (replaced my 21 y/o Norcold).
Looks great. Which model Truck Fridge did you buy? I'm looking to replace mine and it looks like the same size, in a RB50 SMB plan.
04-07-2021, 06:35 AM
#46
Originally Posted by JoeH
I went with the TF65 AC/DC and utilized the link JoeH provided ^^^ to make sure the two models were interchangeable. Notice that the link doesn't list Truck Fridge (since it's a marine site), but I assumed the Isotherm units would have the same dimensions as the TF versions.
06-21-2021, 09:34 AM
#47
Steve C, I don't see the TF-65 on that suremarine reference chart. How did you know it would fit? And in your pic, where is the vent?
06-21-2021, 08:23 PM
#48
Since the Isotherm and TruckFridge units are manufactured by the same company, I just inferred that the Isotherm CR165 was the same as the TF65. Of course I paid close attention to the measurements for both Isotherm and TF models and they did indeed match. As far as venting, I didn't add anything other than the original spot as built by Sportsmobile. There is about a 1/2" gap under the refrigerator and a decent gap between the van's wall and the panel behind the driver's seat. If that clearance was good enough for 20+ years for the Norcold, I figure it will be good enough for the TF as well? I sure hope that my reasoning is sound.
