My expansion tank will be under hood and I will have a 3-way summer valve, too.
I don't have the Rixen coolant tank... that functionality, for me, will be split across 2 components. I purchased this already and am looking at something like this for the AC heated / insulated buffer tank.
Good enough for me! $66 on Amazon it looks like. I have an email out to the guy I bough my current heat exchanger from to make sure it's not my mixing valve that is the issue.
I'm not certain yet that that "point of use" water heater is totally legit for this application, but I don't see any reason why not yet. Seems the temperature and pressure relief are sufficiently high that it will just act like a more affordable insulated buffer tank.
you running the coolant or the water through the buffer tank? Rixen doesn't have a pressure relief valve on the water side and the expansion take with the radiator type cap should act as a pressure relief for the coolant as well as letting air in/out as you go up or down in altitude.
I'm running coolant through the buffer tank. My expansion tank's 7-lb cap will appropriately make it act as the expansion tank. The 100-lb relief valve on the buffer tank should be moot given the difference. Any pressure vessel should still have a relief valve of some sort though, IMO... so, I think all is well.
I'm going for a very large coolant capacity to:
- Reduce cycling
- Provide lots of heat capacity for very long shower duration
And, I'm going with an adjustable electric heater so I can toggle back and forth between asking less of my batteries and asking more of shore power.
I might still be missing something, but if I am, I'm not seeing it.
Fwiw... I'm a huge skeptic that a 17,000 btu / hr Espar D5 truly provides continuous on demand water.
Shower heat demand from the system:
1 gpm * 8.34 lbs / gallon * 50 deg F = 417 btu / min = 25020 btu / hr
Energy input into the system:
17000 btu / hr = 283 btu / min
I do not see how that can possibly provide continuous on-demand showers... hence the "shower-sized" coolant capacity. I figure a 7-gallon heater ~ a 6-gallon marine water heater sans heat exchanger coil.
