Old 08-06-2019, 12:31 PM   #11
Originally Posted by bet on black View Post
i moved my 4 person bench forward. i drilled the holes to use the 6 bolt plates (that the 4 person bench uses) and used large fender washers on the nuts in the new holes, and used the 4 existing holes from he drivers side bracket with the stock bolts.
So, to secure the 6-bolt plates, you drilled the extra two holes through the floor then secured the bolts on the underside of the van with fender washers and nuts. The other four bolts just used the existing holes?? ...just trying to visualize
Jean Claude Van Dad
killacks is offline   Reply With Quote
Old 08-12-2019, 02:58 PM   #12
bet on black's Avatar
yes sir. pretty sure that's what i did, although it has been almost a year. for the passenger side, you need to drill all 6.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 08-12-2019, 03:12 PM   #13
mikracer's Avatar
Thanks for the help. I suppose I’ll seek out a 3-person bench instead of the 4.
Do all stock 3-person benches mount similarly, or is the bench immediately behind the driver different? For some reason, I have the notion that the width between legs is not the same.
Isn't there a row that has an armrest and one that doesnt? I vaguely remember people putting a specific bench in because of the armrest.
mikracer is online now   Reply With Quote
Old 08-12-2019, 03:20 PM   #14
In XLT (or better) trim all the benches got armrests in XLT trim, except the 4 person bench.
In XL trim, nobody got armrests.
Old 08-12-2019, 09:44 PM   #15
Went with a 3-person bench, after all. Just scored one today from a local forum member.
The kids are stoked on their new seating situation. Unfortunately, they will not know the luxury of the armrest option but they’ll never be the wiser
Jean Claude Van Dad
