01-20-2021, 02:47 PM
Sportsmobile Overhead Console
So I am in the works on my ground up build( link), and I keep jumping around from project to project and keep coming back to the idea for an overhead console. I want to try to match the same design that Sportsmobile has in their builds, but I'm having a hard time finding good reference pictures/ info on how its done. I have seen a few pictures on the forum of people in the middle of taking it down, but no details of how it attaches to the headliner section/ceiling members.
Some Images From the Web
So If anyone has some pictures of knowledge it would be greatly appreciated.
Below are the main things I'm trying to figure out.
Questions:
Are the visors mounted in the original holes with the shelf notched around them, or are they remounted on the flat surface of the console shelf?
How is the console secured? I am assuming some combination of L brackets and self tapping screws into the main roof structure.
Is it just a stock headliner rewrapped in custom upholstery or is it some kind of custom headliner insert?
Thank you in advance!
Vandit - 2013 E250 Ground Up Build- Full Custom DIY Interior Build
- DIY U-Joint Off Road 6" 4x4 Conversion
01-20-2021, 05:23 PM
I took a bunch of pics of this very thing from my 98 SMB just before I sold it, as I was/am planning to replicate it for my 2011 SMB that doesn’t have one. It’s pretty basic, just 1/4 plywood wrapped in fabric with a few wood blocks attached. Mounted to the ceiling with one l-bracket and the sun visor screws. Here are a few pics that I can find right now.
01-20-2021, 06:45 PM
Attachment 37908
Thank you, that helps a lot! If I’m understanding correctly the visors mount to the headliner through those large holes in the corner, right?
01-21-2021, 06:11 AM
Yes, they do.
I came up with mine from scratch after seeing some pics of SMB ones. They are deep in my gallery somewhere. Did you see those? If not I can dig them up. As far as I know I am the only person who has taken a lot of pics of this but I certainly could be wrong.
As for mounting it to the roof you need to pull your headliner back and get a feel for where the double/reinforced sheet metal is near the windshield with a gap in between. You can screw in to this about anywhere with long sheet metal screws. It's pretty iffy how you have to mount one but it stays in place. You could get fancy and add some nutsert/rivnut type of things to the interior sheetmetal but it would require tearing up your headliner a good bit more.
01-21-2021, 07:40 AM
Two areas that will be your challenge-
1. Center rear support bracket - using the windshield stock doubled up metal along the front is easy. the rear center is more difficult as there is no doubled up metal there. If you have a CCV pop top you can just go through the roof metal as it is covered by the storage platform above. SMB pop top or stock roof will require a bracket to be glued or UHB taped to the inside surface.
2. The sun visors - to have them properly function and mount will require a spacer (like a puck) which will replicate the original mounting point and angle only lower so the visors clear the console. Drill a large hole as in BrianW pic, mount the puck to the original metal using offset metal screws. Then mount the visor to the puck spacer. The visor clips can be mounted (properly positioned) to the underside of the console.
01-21-2021, 08:40 AM
Originally Posted by 86Scotty
Yes, they do.
I did come across your build thread on it! That was helpful and got the ball rolling for me. The thing I was unsure of was the whole visor part and how to get retain the function of them. Since I already have the headliner out and plan on reupholstering it I like the idea if rivnuts.
Thanks for this info Ray! That makes perfect sense about using essentially a puck to just lower that mounting point while keeping the angel to retain functionality. I Will have to use some kind of glue for the center mount as my van is still stock for me.
Also I saw that your family was having a real nightmare with Covid. I'm glad to hear that things are headed in a better direction and your mom is doing better! Its good to see you back on here.
01-21-2021, 09:13 AM
Here's a bunch of pics I took before I sold my 98 van with the visor. Still hope to make a new one for my 2011.
01-21-2021, 09:16 AM
And some more. There were no additional supports for the visor brackets, they just screwed through the plywood and into the OEM holes. The center had a piece of metal bent into an L-bracket screwed into the OEM headliner (IIRC) and then the shelf screwed into that.
01-21-2021, 09:29 AM
Found a few more that should help with the attachment details. So the attachment points are visor swivel bracket, visor clip bracket, center L-bracket, and screws at the edges (snap-top upholstery screws that double for the front-window curtain). Also shows where I ran wiring and antenna wire for a CB that I had installed in the shelf.
01-21-2021, 09:42 AM
Thank you For all the pictures and measurements! These are going to be a big help. I feel like I have a pretty good plan now. I will try to remember to take lots of pictures during the process and upload them to give more info for the next person who decides to do this.
