Originally Posted by Arturo
Another issue is that the spring in the channel on the driver’s side does not remain in the channel. It rases up about an inch or two above the channel. The passengers side remains in the channel. NEEDS WORK !!!
Second Boy Wonder's comments...Having been thru the broken, actually unscrewed fasteners, parts are not unique. Fender washers, nylock & jam nuts, and grade 8 bolts......Looking at the springs you will probably notice the difference causing the channel spring issue...Several of the channel bolts were fastened without nylocks (texas build)....Also washers/spacers serve to better align the bolt loads between channels and lift mechanism...
I believe I posted some pics a while back as well....
Supporting the top and lowering the mechanism relieves the fastener loads...
A number of write-ups on that...
