Is your gaucho set up where the sliders are on the sides of the seat, under the upholstery, and are bolted at the back with a single bolt that acts as the pivot point when you raise the seat (like mine)? I had my sliders fail outright - break apart. I ended up going to the hardware store, finding a cabinet slide of the appropriate specs (short enough to be installed when collapsed, long enough to allow the extension, heavy enough to take the load), then taking the seat loose, removing the upholstery and putting the new slides in.
