Old 02-02-2020, 08:19 AM   #1
Belize's Avatar
Swap heater for a/c?
My 2006 Ford E350 SMB has a Suburban propane furnace in a RB50 build. I will not need the heater where I am going, but will need a rear a/c. Asked SMB Texas about the conversion and they quoted +$6000 and 10-12 weeks. Ouch. Looks like Danhard is my only option (not interested in an exterior unit). I am pretty handy. Anyone have experience or advice on a DIY heater removal and a/c install?
Belize is offline   Reply With Quote
Old 02-02-2020, 09:16 AM   #2
1der's Avatar
Just thinking out loud -
Possibilities of installing an efficient 120v powered unit and running it off the inverter?
Roof Top A/C except shrouds are pretty big?
A/C unit out of an All electric car?
A few people of installed bedroom window units in the rear door window locations.
Old 02-02-2020, 10:44 AM   #3
Running an adequately sized AC off an inverter will be quite the challenge, but a soft start will certainly help. Roof top units work well but are heavy and require a generator. This question comes up every summer so a quick search of the threads may find a good solution, please post your solution.
Old 02-27-2020, 11:38 AM   #4
I have an IndelB fridge (from Truckfridge) and have been pleased with it. Have you seen their website with 12v/24v air conditioner products?
https://www.indelb.com/products/auto.../sleeping_well
maptester is offline   Reply With Quote
Old 02-27-2020, 11:56 AM   #5
Danhard makes a self-contained marine A/C rated for 6,000 BTU, that might fit your furnace compartment. It draws 5.7amps at 120 volts, so a modest pure-sine inverter would power it (modified sine will increase the current draw, and make it run hot and could shorten its life).
https://www.marinaire.com/Marine-air...BoC9xwQAvD_BwE
6,000 BTU won't cool an already hot van, but it should keep it cool if you use the dash A/C for initial cool-down.
Old 02-27-2020, 04:16 PM   #6
Check out Dometic Under Bench unit.
You would also need the installation vent kit
Faultine
rizzabove
Agnes
ranchero
