02-21-2019, 06:20 PM
#31
Will surely post pictures. My plan is to install it under the sink in the restroom. I has stuff stored there that I have not used in 18 years. Time to get it out of there and make room for the heater. I am hoping I will clear the frame. With the heater and air return there the cabinet and the water tanks should be warmer. A plus I think. I am going back and forth on having the 10L fuel tank (will use K-1 kersene) mounted inside or outside the rear door. Inside easier, outside safer in a rear end crash.
Len & Joanne
The Green TARDIS
02-21-2019, 06:54 PM
#32
I bought the same heater, so far so good!
There is a facebook group if you need support (mine didn't come with instructions and the seller wasn't able to provide)
Here is a youtube video that shows how to operate the thermostat:
2008 E350 RB 6.0 - Bullet Proofed, MG 4x4 Conversion
2009 E350 RB 5.4 - Camburg Kit (Sold)
02-21-2019, 10:48 PM
#33
Originally Posted by gnty
We have the Planar heaters here and am faced with the same dilemma, diesel heater in a gas van. I certainly agree with what has been discussed, both the pros and cons. There is really no clear answer but personal choice based on comfort level of having fuel inside or outside of a van.
The Planars come with a fuel tank and Planar said that people have been mounting this inside vans and running the heater off of kerosene, what are the thoughts on this? Safer? More peace of mind?
I put a Planar diesel furnace in my gas Ford Transit and it was amazing. I recently sold the van but it was one of my favorite mods. Amazing output in a tiny footprint. Also, 7 liters of diesel ($5, give or take) would heat the van for days on end.
No need to use kerosene. Why would you? I filled up the 7 liter diesel tank of my Planar right at the pump while pumping gas many times. My tank was just inside the rear doors. As long as fill carefully and don't spill it there is no odor or problem. Same goes for kerosene.
02-21-2019, 11:05 PM
#34
I have read that Kerosene burns cleaner at altitude vs. diesel. Supposed to be less likely to foul the glow plug when running at altitude, etc.
I have also read that the controller shown above might be programmable for dealing with altitude (slows the pump to lean the afr back out).
02-21-2019, 11:23 PM
#35
So far I'm holing out on installing a heater. Are there any budget gasoline options out there?
(I may be willing to spend more money a couple months from now, but right now I'm clamping down again.)
02-22-2019, 01:17 PM
#36
That I did not know. I know some use it for a cleaner burn but if you use only diesel and use it regularly, remembering to crank it up to full blast for 5 minutes or so before shutdown now and then, you'll have few issues. At least I never have. I do not live at high altitude but have camped at altitude several times with no trouble.
There are no budget options for anything on this forum. Espar/Webasto do make gasoline units. Michael (MGMetalworks) put one in his Transit and loves it so far. *They are NOT cheap. Propane is cheap.
02-22-2019, 03:35 PM
#37
Fork-N-Road: Thank you for the video. So far, by reading this thread, I think the Chinese units are smaller and possibly electrically more reliable than my Webasto -- and certainly cheaper! I think I could fit both an air heater/furnace and an engine coolant heater under the Engel Fridge Freezer in my van (well insulated of course). Amazing to see this kind of progress.
Question: Would some of you brainyacks please do a BTU output comparison of Propane to Diesel?
Why?
1. It would help some people decide on Propane v. Diesel for their vans; and
2. It would help me decide if I should run a propane gas line from the tank to my shop in the snow or just buy one of these and stick a small diesel tank on the outside of the shop.
02-22-2019, 03:37 PM
#38
Paid an arm and a leg for my Espar B4. It cranks.
Had the van down to 5 degrees F. No worries.
tell you what though, if that 150 dollar chinese unit works that's a hell of a deal. If breaks just buy another. Might even be made in the same factory as espar or webasto.
For that money I would have done what Scotty did and put a diesel fuel tank in the van.
Only issue I see if there is no altitude compensation. I regularly camp at 7-9000ft. Gotta have that heater working.
<br>
04-21-2022, 09:39 AM
#39
Originally Posted by brp
The Dickinson Newport heater is a nice option. It takes up space but is very nice looking and the visible flame gives a nice warmth/ambiance. It’s available in propane, diesel or wood fired.
Does anyone have any firsthand feedback on the Dickinson heater?
Thanks,
04-21-2022, 04:50 PM
#40
Does anyone have any firsthand feedback on the Dickinson heater?Thanks,Herb
Herb, sorry but I don't have any Dickson experience. I do have a lot of experience with a Chinese diesel heater though. On the plus side, they are ridiculously inexpensive, use minuscule amounts of fuel, come in a kit that includes EVERYTHING needed to install, they are very quiet, on low they draw less than 0.5 amps and they are small enough to allow numerous mounting options. In Jan I camped in below zero temps and was toasty warm.
On the minus side, they almost all run on diesel so if you have a gas van you need to mount the included fuel tank, the 5kw can be a bit much in temps over say 35f to 40f, but cracking a window is an easy solution, there is a bit of a learning curve but there are easy answers to every question or issue on Facebook and other sites.
All in all, the $140 I spent on it is by far the best bargain improvement I ever made to the van. I actually bought two and stripped on for spare parts, but so far I've had zero failures in two seasons.............
