Originally Posted by marret
I need a right side crank as both of my windows have the crank on the right side.
Are there two different gear boxes for the FW904RS? Do all of them have right side cranks? You listed one part number.
Looks like the FW620 series have left or right versions.
Thanks, Chris
The FW904RS all hand cranks on the right (when viewing from inside). I was never aware of the existence of what would have been a FW904LS.
Of note: Sportsmobile did install, in some vans, an exclusive to them CRL awning window that looks very similar to the FW904RS. It was a bit wider and taller. It was not available to DIYers. So, measure to see which window you have. The crank mechanism should be the same. A glass window replacement obviously would be different.
Now I see CRL is listing a FW632RS w dims of 41-1/4" x 25-3/4" - it is not in stock. On an E Series it will require a cut that extends below the upper part of the mid-body line. For reference the FW904RS is 33-3/8" x 19-1/8".
