Old 11-28-2021, 03:04 PM   #61
northleftcoast's Avatar
2021 Underfloor Price Update
Underfloor Box Price Update November 2021
Please note the adjusted pricing for boxes below:
$400 Standard sized box for EB or RB vans: (15.5" x 15.5" x 32")
$500 XL sized box for RB vans ONLY (15.5" x 24" x 32")
* Boxes are made out of 5052, .125" sheetmetal. All corners either bent or tig welded. Standard size cut opening is 12" x 24" with a 1" flange for carpeted surfaces.
* Access hole rimmed in black vinyl trim.
* Box top flange of 6061, 1/8" bar stock of your choice of height (1", 1.25", 1.5") based on your flooring+subfloor dimension needs (no charge).
* 4 - 2 x 2 x 7/16" spacers for mounting (6061 barstock tacked together).
* 4 - 2 x 2 x 3/16 "washers" (6061 bar stock cut to length).
Options:
$225 Lid/hatch with interior 6061 1" angle flange and aluminum piano hinge.
$20 Aluminum bung with tapped 1/4" npt hole and plug for drainage on an outside corner or bottom where you determine.
$75 Custom size. Subtract depth, width or height, or offset the lid to your drawn dimensions.
$50 Cutaway lower trailing edge for better departure angle (your choice of angle).
2003 Ford E350 PSD, EB Cargo, Quadvan 4x4
northleftcoast is offline   Reply With Quote
Old 02-02-2022, 02:39 PM   #62
jeff.depaul's Avatar
Perfect, I’ll take some measurements and get back to you. Thanks
jeff.depaul is offline   Reply With Quote
Old 04-21-2023, 08:21 PM   #63
I sent a PM but I’m wondering if @northleftcoast is still building these boxes?
SquamptonBC is offline   Reply With Quote
Old 08-11-2023, 08:13 AM   #64
Originally Posted by GBreezy View Post
I finally installed my box I bought from Sam. I went with the dimensions 15"x15"x32" because I felt 15 1/2" was going to be a little to tight. Once I got it, I am glad I did because I do not think it would fit without some major work
What major work did the half inch reduction save you?
06 E-350 EB 6.0 Suckless Quigley (Bulletproofed with RIP)
seal is offline   Reply With Quote
Old 11-07-2023, 07:35 AM   #65
Options:
Are you still taking orders for these boxes? Thanks!
crzmky is offline   Reply With Quote
