Has anyone removed the exsisting brackets that are thru bolted into the body? Looks like they may be a pain to get too. My sheetmetal on the center bracket is cracking, thus why I am replacing.
Indeed - just installed my set with an ARB (non-aluminum) awning over the weekend on my high-top e350. Not sure about the aluminum ARB but after drilling a few holes and lining everything up they worked like charm in conjunction with the fiberine bubble top.
Originally Posted by snowgroomer
Will these work with the Aluminium case ARB? Will the work with a high top
Doug, if you have part of the gutter exposed, you should be good to go. If any question, post up a picture of the top to gutter area and I will let you know.
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
