Old 07-10-2016, 10:39 AM   #91
LastBlackE350's Avatar
Hi Ray,
Please put me down for a set of ARB 2500 brackets. Hope you still have some cause I just ordered the ARB 2500 from AutoAnything. 20% off Sunday only sale = delivered for $231.80..
Lyall
LastBlackE350 is offline   Reply With Quote
Old 07-10-2016, 11:04 AM   #92
1der's Avatar
Yep, have around six sets left. Payment info is about six posts back. Thxs!
Old 07-10-2016, 11:28 AM   #93
Excellent, pmt has been sent!
Old 07-11-2016, 07:17 AM   #94
alta825's Avatar
Question for those who've installed these brackets on a SMB with the original brackets that bolted into the sheet metal.
Pulled the awning and brackets off the van yesterday and the original nut-certs have an integrated rubber washer - seems like it is part of the insert - guessing I should I trim it off with a razor blade?? any other install tips other than an extra set of hands? didn't realize how heavy the awning is
Thanks
-d
2002 EB51 7.3L w/ Stage 2- UJoint 6" 4x4 Conversion
2001 RB50 V10 Quigley- SOLD
alta825 is offline   Reply With Quote
Old 07-11-2016, 11:29 AM   #95
Ray sent off payment, Just wanted to make sure you got it. I am needing the mounts for the fiamma not ARB.
Thanks Again,
James
Jaimes35 is offline   Reply With Quote
Old 07-30-2016, 07:39 AM   #96
Just sent payment on arb brackets and a long door talon
Thanks ray
jekaio is offline   Reply With Quote
Old 07-30-2016, 09:17 AM   #97
1der's Avatar
Thanks ray
Thank you!
Old 08-05-2016, 12:07 PM   #98
Shaggy's Avatar
Interested but have an issue. I own a e350 ext passenger wagon with all the windows, I'm thinking your brackets wont work?
Shaggy is offline   Reply With Quote
Old 08-05-2016, 12:58 PM   #99
1der's Avatar
The brackets work fine with or without stock windows, or CRL windows. If you are still concerned, please post or email a picture of your van, and I will be able to see for sure.
Thanks!
Old 08-05-2016, 02:44 PM   #100
1der's Avatar
Originally Posted by freddiejohn View Post
Hi, Just saw your post. I'm interested in what you've done with changing brackets. I've got the SMB brackets now, bolted through the sheet metal. When you changed to the Z brackets did you abandon the holes from the original brackets? If so, how did you seal them off and how does it look? Thanks for any help/advice. John
Hi John, others had the the SMB bolted brackets and changed them to these hr ackets to get away from the issues the SMB's were creating. Holes were sealed and, in most cases, the new brackets covered, or nearly covered the holes.
Somewhere, I did a measurement of how far down the middle and rear brackets go. I will see if I can find it. If you look at the very first post in this thread, there are pictures you may be able to use as a gauge.
