Originally Posted by CamperDude
What brackets should i use for a Thule Outland awning? Will your brackets work?
Love that new, less expensive awning! I'm one of the few (?) on here that has a Thule awning. If your awning has the same attachment system as mine, you can take a look at my install here on Yakima roof racks:
https://youtu.be/O9zV44Vm82s
After my CCV poptop install, I used 1der's brackets for my Thule install. You can see some info here:
https://www.sportsmobileforum.com/fo...-17377-15.html
So the answer is yes, you can use these brackets if: a) you're installing on the E-series gutter/drip rail and b) you're willing to drill a few holes to accommodate the different setup of the Thule (that is assuming that YOUR Thule is the same on the back as MINE).
