Originally Posted by tedujam
My driver side swivel mount doesn't line up quite right with the seat bolts. Does the swivel base need to be drilled out first?
hi James, what has happened here is the seat slides have become misaligned with each other. This usually happens when the seat has been removed from the stock base, and the seat is lifted by the slide release handle. What can happen is the two slides move independently and then become misaligned. This causes the bolts on the slides not to line up correctly with the holes in the seat base.
To correct this misalignment, the best way I found is to line up one seat slide with the holes, and then lift the slide handle to disengage the two slides from each other and slide the other track to where it will line up with the holes in the seat base.
No drilling is required to mount these. They are direct bolt in. Thxs!!
