Old 09-10-2021, 08:54 AM   #631
Originally Posted by 1der View Post
btw , the driver swivel base works with the UJOR floor shift, just in case you or others were thinking it would not. Swiveling the driver even 90 deg is a huge upgrade to the front cabin area functionality and comfort. The bases do not work with power bases.
Good to know, thanks. Unfortunately (or fortunately?) our driver side seat has a power base. We may decide to find a non-power driver seat down the road, depending on how we end up using the van.
motovan_mn is offline   Reply With Quote
Old 09-11-2021, 05:09 PM   #632
Hey all, just a quick question, it may have been discussed prior, but i dont feel like going through 64 pages to find out.
I'm about to install these. Most videos show the removal of the carpet and insulation and bolt these directly onto the steel floor. I am thinking about heat transfer (loss) and was wondering if anybody left the carpet and insulation in there, thus preventing a big thermal bridge between floor and seat base. Any reason not to do that? I assume that if you bolt them down tight they will not be wobbly?
Mushin is offline   Reply With Quote
Old 09-11-2021, 09:39 PM   #633
1der's Avatar
install video we did. Thd insulation can be left. In a passenger van, the carpet will need to be cut a bit where it is "formed" otherwise it will bunch up and create problems with the plate.
Link and check time codes to jump to particular install points:
https://www.blingmyrig.com/pages/swi...c5379a6d&_ss=r
Old 09-13-2021, 11:39 AM   #634
1der's Avatar
I am putting together the next buy. Target is mid to late October shipping. Let me know if any questions.
Questions I hear about Driver seat:
Driver swivel with a transfer case floor shifter - in 99% of the cases it can.
Driver Swivel with cabinet behind - Driver seat can swivel with cabinet behind.
Driver swivel - The HUGE benefit of a Driver swivel is not 180 degrees as with the passenger seat. It is the ability to rotate it 90 degrees (although it will rotate 180) that we find the most beneficial. It opens up the front area by moving the back up against the door, provides another seating spot that allows the person sitting there to be part of the cabin experience, and makes the driver floor area easily accessible for stowing/retrieving bags or stuff.
Install video link is here:
To Order:
https://www.blingmyrig.com/collections/all-toys-bling
Thanks!
Old 09-14-2021, 06:39 PM   #635
2011 Ford E150 passenger seat desired - please PM me for zip code info
oregonfordvan is offline   Reply With Quote
Old 09-28-2021, 10:17 PM   #636
To Order:
Thanks!
2012 E350 swivel seat base for passenger seat. Very interested if available. Zip is 83815
Johnson is offline   Reply With Quote
Old 09-29-2021, 02:59 AM   #637
1der's Avatar
To Order:
Old 10-27-2021, 08:22 PM   #638
1der's Avatar
I have a few swivel base units left for shipment this coming week!
Next batch is targeting end of January.
Lots of info on the order page, too.
To Order - go to:
Thank you!
Old 10-31-2021, 03:55 PM   #639
Great swivel, question on unit under seat
Just got my 2 swivels installed in about an hour total
On the passenger side there was this box under the seat. Anyone know what it is? Seems related to the airbags. If it’s unplugged the warning light about airbags stays on. The base won’t fit over tit so I had to unscrew it and mounted it on top of the base
Anyone know if it’s okay to just mount this on top of the base plate and secure it facing forward?
That’s what I Did and seems fine but can’t find anything online on what this box does and would hate for the airbag to deploy
richados is offline   Reply With Quote
Old 10-31-2021, 04:26 PM   #640
I think it’s the yaw sensor for RSC. Weird that it would trigger the airbag lights. Regardless, Just make sure it’s still pointed forward l, and can’t be kicked out of position, and you should be ok
Behemoth
Besags
Dodge
lugee
