Originally Posted by berns378
C YA FOR GOOD!
Yes please! For real this time?
Honestly, I am amazed you've actually made it this far with an SMB. PSA: SMB's are custom aftermarket vehicles which require you to devote a little bit more time and effort than a stock OEM vehicle. If you are not handy, don't have the time or the desire, and/or lack the mental capacity you should do yourself (and us) a favor and seriously reconsider your investment.
You've wasted more time blowing up this thread than it would have taken you to troubleshoot and fix the relatively simple headlight issue you had. I got headlights from Scott. I have never installed headlights before. I had a couple challenges during the installation: hard to fit ballasts into space behind headlights, brights didn't work at first, lights were dim... I spent an extra hour or two troubleshooting, I google searched, I tried a couple different things, I reversed the connections on to the existing plugs, I improved the ground connections and... guess what? I figured it out! The headlights work great and are an order of magnitude better than the originals. At ~$300, this simple upgrade probably has the best ROI of any I've done so far. OK may be a toss up for the door talon (which I installed myself in 20 minutes!).
Sorry if I sound like I'm attacking you. I am...since you have gone above and beyond incessantly pissing on Scott and spreading your negativity around this forum for a problem that only YOU seem to be having. Now STFU and go away for good please.
