Old 08-02-2021, 11:57 AM   #631
Twoxentrix's Avatar
Originally Posted by Youngster View Post
Hi Scott. I sent you an inquiry last week to your Vantage gmail, as a reply to my original order (Order 364).
One of my new Vantage headlights stopped working after a year. I need to know how to trouble shoot and what parts will be needed. Can you check your emails and get back to me?
Thank you!
-David
I've had this happen twice, and Scott has been great guiding me through - I'll let Scott chime in, but try these two first:
First thing to do is rule out the bulb. Take the bulb out of the one that works and try it in the one that doesn't. if the good bulb works in the bad headlight then its probably the bulb...BUT, Check the GROUND contacts (this was MY PROBLEM BOTH TIMES - and an easy fix)
Old 08-02-2021, 12:15 PM   #632
REDOVAL's Avatar
Thank you!
-David
Responded
Scott Thompson
Vantage Optics
vantageoptics.com
Vantageoptics@gmail.com
2002 Ford E350 V10 Traveler
Vantage Optics Headlights
www.VantageOptics.com
Old 08-02-2021, 12:33 PM   #633
Youngster's Avatar
TwoX, excellent advice.
Scott, I'll try your suggestion this weekend.
Thank you both!
2016 Beta 500 RS
2014 KTM 350 EXC-F
Youngster is offline   Reply With Quote
Old 08-10-2021, 08:19 AM   #634
REDOVAL's Avatar
Apparently it's August already! Use code VOSMBAUG21 to save 10% on all purchases on the site.
Have an idea of what products we should look into making? Let's hear them!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 08-10-2021, 10:09 AM   #635
Anyone who buys a set of Scott's fantastically awesome headlights should also consider buying headlight protection film to protect your investment
https://www.weathertech.com/lampgard/
and it's super easy to install!!!
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 08-10-2021, 10:34 AM   #636
REDOVAL's Avatar
Unreng- are these still available? I haven't checked in a little bit but they were out when I went to make a bulk purchase. I do run these on my personal lights and highly recommend them for all lights. Be aware though, they will look very bubbly for a week or so after installation but will smooth out perfect once they dry.
Thanks for the info!
Scott Thompson
Vantage Optics
vantageoptics.com
Old 08-10-2021, 10:41 AM   #637
bought a set last month from weathertech.
fyi - threw away the film for the marker light as it was not sticking.
Chris
Old 08-10-2021, 10:46 AM   #638
REDOVAL's Avatar
Awesome, thanks for the update!
I don't think I used the film for the markers either, likely for the same reason. I wasn't as concerned since they are a rather simple replacement item that I normally stock many of.
Scott Thompson
Vantage Optics
vantageoptics.com
Old 09-02-2021, 09:17 AM   #639
REDOVAL's Avatar
So here we are in September now with Labor Day right around the corner. We will be running a special sale from Sept 3 to Sept 7 with coupon code "LABORDAYVO that will be good for 10% off and free shipping for all items. We have tried our best to minimize lead times and keep the shelves stocked!
Once Sept 7 passes we will have coupon code "VOSMBSEP21 available for 10% off for the whole month.
Scott Thompson
Vantage Optics
vantageoptics.com
Old 09-13-2021, 02:00 PM   #640
bigriver's Avatar
I just installed the backup lights, turn signals and relay. Easy peasy install and much superior to stock. Good stuff Scott.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
