Old 04-27-2020, 10:37 AM   #11
dhally's Avatar
It's amazing how much noise comes through a hole in the floor.
2009 E250 RB 5.4L "SilVan"
Old 04-27-2020, 02:30 PM   #12
gahamby's Avatar
Had a true POS company van like that. I took packing blankets and spring clipped them to the roof cross member behind the seats. Got it down to a dull roar. While it's all stripped out consider routing some ENT(Smurf tube)
that the communication techs use to run wire through. Run pull string through it. You never know when you will want an extra wire.
Good luck with the project.
'07 GMC 2500 6.0
Old 08-19-2020, 10:19 PM   #13
Update, with progress and pictures!
Sprayed Bully Liner on the floor, full coverage with Kilmat plus a layer of 1/4" closed cell foam. 5/8 plywood over that, with 3/8 plywood fender boxes.
Pop out windows in the back and side doors.
Cured the rusty old bumpers, KC lights, and a Redarc brake box.
Passenger side swivel seat base.
Lots of general maintenance, new tires and shocks, and recovered the headliner, changed to a late model console, and put in a shelf-it over the windshield.
Then the big one, the trip to Fiberine for the 20" aero top. Went great, the folks at Fiberine are a class act.
Now I'm working on insulation, overhead cabinets...
20200424_133241.jpg   20200516_120149.jpg   20200521_193525.jpg   20200523_201141.jpg   20200531_121913.jpg
loper is offline   Reply With Quote
Old 08-20-2020, 03:29 AM   #14
marret's Avatar
Great to see progress and I like that top. Thanks for posting.
Chris
Old 08-20-2020, 09:04 AM   #15
Glen's Avatar
Looking Good...
What did you use to fill the holes in the floor with?
Friends Don't Let Friends Do Stupid Things Alone
Glen is offline   Reply With Quote
Old 08-20-2020, 09:16 AM   #16
I used some Dorman plugs. I mixed up some epoxy, dabbed it around the hole, on the bottom/stem of the plug, and covered the plug after I put the plug in.
I'm thinking that sealed the hole, adhered the plug into the hole, and the top coat will protect the top of the plug.
Old 08-20-2020, 10:42 AM   #17
BrianW's Avatar
More details on the Shelf-It, please! First I’ve heard of it. My old SMB had the SMB-installed shelf but my new one doesn’t. How well does it fit, quality, etc.
Old 08-20-2020, 03:31 PM   #18
I'm pretty happy with it, but they have changed the design a bit from the last one I had.
The shelf has brackets that screw in where your sun visors screw in. The visors go back onto the bottom of the shelf, but reversed (they flip back towards you to go down).
You have to do a bit of work to move the center supports for the visors down to the shelf (drill a couple holes and trim the back side of the supports), and you need to put something back where the center supports were or the headliner will droop.
It ain't that hard, and I like the extra stash space up front for road trips. Eventually I will have a switch panel up there for side/rear lights, a front led bar, compressor, etc.
Pictures to explain, and a link from amazon:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 08-21-2020, 06:39 PM   #19
Insulation work!
We had Fiberine glass in 1/2 inch osb on the ceiling and 1x6s down the sides so we would have some anchor points.
Started with Noico red in the nose, and glued up some 1/4 closed cell foam reflective insulation over that.
On the sides I went with 1/2" rigid styrofoam, a layer of the 1/4 closed cell stuff, and another layer of 1/2" styrofoam between the uprights for the siding. I will close all that off with plastic sheet (vapor barrier) before I run the wiring and hang the siding.
For the top I'm just using 1/2" styrofoam, 1 layer of 1/4 closed cell foam, vapor barrier, and 1/8" plywood sheeting.
There is a bit of rock wool invloved in some corners and crevices, and 1x2 stringers to hang everything on, but that's about it so far.
20200819_151035[430].jpg   20200821_143819[454].jpg   20200821_143825[449].jpg   20200821_143834[448].jpg   20200821_143837[447].jpg
