Thread Tools Search this Thread Display Modes
EB Van
ebflow's Avatar
ebflow ebflow is offline
Vehicle Name EB Van
Year 2003
Make Ford E350 Super Duty HOLY GRAIL
Model Econoline
Color Blue
2003 Ford E350 Super Duty HOLY GRAIL Econoline
2003 Ford E350 Super Duty HOLY GRAIL Econoline 2003 Ford E350 Super Duty HOLY GRAIL Econoline
History Bought From a rafting Company in Idaho. 200,000 miles. Then I proceeded to do the 7.3 Bullet proofing and Refreshed the engine. The Eb Van has been through the works! with quality and a lot patience in mind. Everything was installed by myself or custom fabricated specifically for the EB van. This is a Dream Rig for me and many others. I hope it can inspire people! as I was when I joined the Sportsmobile forum. Thank you!
Exterior
Self Installed. Ujoint 6" Kit, 35" Toyo RT, Colorado Camper Van Hi Top Pop up. Ujoint Bumper, Ujoint Fuel Tank. RaptorLined Hi-top, and rocker panels, and van top. Air Vents in hood.
Interior
2003 Ford E350 Super Duty HOLY GRAIL Econoline Interior 2003 Ford E350 Super Duty HOLY GRAIL Econoline Interior 2003 Ford E350 Super Duty HOLY GRAIL Econoline Interior
Custom Camper Interior Build(building now) 2x Custom underfloor storage boxes built by northleftcoast. One in far rear position, and one behind rear axle and crossmember (custom crossmember relocation needed) MorRyde Cargo Glide above the storage boxes, pulls out for access.
Wheels, Tires, & Suspension
2003 Ford E350 Super Duty HOLY GRAIL Econoline Wheels, Tires, & Suspension 2003 Ford E350 Super Duty HOLY GRAIL Econoline Wheels, Tires, & Suspension 2003 Ford E350 Super Duty HOLY GRAIL Econoline Wheels, Tires, & Suspension
35" Toyo RTs, Ujoint 6" Kit, Dana 60 front(4.10), Sterling 10.5 Rear axle(4.10) Detroit Truetrac, High Angle Drivelines, Fox Shocks.
Under the Hood
2003 Ford E350 Super Duty HOLY GRAIL Econoline Under the Hood 2003 Ford E350 Super Duty HOLY GRAIL Econoline Under the Hood 2003 Ford E350 Super Duty HOLY GRAIL Econoline Under the Hood
7.3 Powerstroke Diesel, 4" Dual Air Filter Intake. 4" Diamond eye Exhaust. Custom Fuel Bowl Delete/regulated return, Max AC, Mean Green Starter/Alternator, Terminator HPOP, Airdog Fuel System, High Flow Banjo Bolts, FS2500 Secondary Oil Filter, Oil crossover. Stock re sealed Injectors. Pure Turbos Turbo w/wheel & 360 thrust bearing, Alradco Aluminum Radiator (running filtered EVANS Coolant) Upgraded tranny cooler/filters. NEW Diesel 4r100 Legendary Transmission + Torque Converter. MAG-Hytec tranny pan. DP tuner 60hp and 80hp tunes. REDHEAD power steering Pump. White Rodgers Glow Plug Relay. 2x NorthStar AGM Starting Batteries.
Systems, Solar, & Electronics
Soon to be
Favorite Destinations
2003 Ford E350 Super Duty HOLY GRAIL Econoline Favorite Destinations
Las Vegas, Sante Fe NM. Washington State. Colorado, California, Oregon. Guatemala.
Old 03-03-2017, 07:58 AM   #2
Good Morning Ebflow,
I see all the work you've done to your 7.3 did I understand correctly can you omit the factory fuel filter and relocate fuel filters to an easier location? My 7.3 is still stock and I just hate to change the fuel filter. Oh and I like your van, does the 4.10 gearing work well with the 35's? O.K. thanks
bad luck is offline   Reply With Quote
Old 03-07-2017, 09:29 AM   #3
Awesome looking machine. Same question regarding 4.10 gearing and 35" tires. I'm planning to switch to 35s myself. Thanks!
Jack K is offline   Reply With Quote
Old 01-28-2018, 10:23 PM   #4
ebflow's Avatar
Yeh I like the 4.10 with the 35's gives it a great get up and go when on throttle.
ebflow is offline   Reply With Quote
Old 01-29-2018, 07:03 PM   #5
Am I the only one that can't see post #1?
2003 Astro AWD
2005 Tacoma Access cab 4x4
Old 01-29-2018, 10:58 PM   #6
Ah, I see it now that I'm on my computer. Couldn't see it on iPhone earlier.
2003 Astro AWD
Old 01-30-2018, 10:36 AM   #7
bet on black's Avatar
i am considering this as well. currently on 35's with 3.73's. even with the truck turbo, it still needs some tweaking to get the powerband lined up with hill climbing highway speeds. also could use a little more grunt from a dig.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 10-15-2021, 12:16 PM   #8
ebflow's Avatar
Looking to Sell my Van, asking 90k taking offers. This this is a GEM. with only 15,000 miles on a complete overhaul rebuild on a 7.3 DIESEL and Ujoint 4x4 kit, Colorado Camper van top and tons more etc. Call me if your interested, can deliver. I have 75k in receipts put into and a complete folder of history and repairs. Located in central Washington 509-860-1007 -Ryan
EB Van
ebflow
LiamMobile
Shyll
