Originally Posted by VanDam
...I was just coming home and the trans reached that temp, I let it idle down for a while at home before shutting it down. Yesterday in a drive it came up to 210 then was back down to 204. Still I’d like to see it back in the 180 area...
Those Trans temps still are not normal for regular daily driving, something else is askew there. Relying on the fan to keep those down isn't addressing your real issue - Recommend you get that issue resolved before you proceed with anything, else you may be masking an problem that could result in considerably more repairs.
You mentioned you just had the Trans fluids changed, have you checked the level? As i stated in my last post, over filling caused my Trans temps to go through the roof. If the level is reasonable, another member here may have some diagnostic suggestion(s), I can only direct you to visit with a mechanic (and have credit card in hand).
