Originally Posted by JabberBox
I would think all they have to do is make one cut in one cable and the convertor would slide right out between the cables or just cut one of the clamps.
Somebody needs to make a circuit using a cable to the convertor as a ground signal wire. If they cut the convertor or the cable it interupts the ground signal triggering some spikes that shoot down out of the frame preventing the would be thief from making a clean getaway. JK
Nobody is going to stop a determined thief..just trying to get them to move on to a softer target. You have to be able to access and cut both ends of the converter to get it out so that was the thought here. You either need to cut two clamps off and do your best to get under the cables or cut a few of the cables.
There are lots of youtube videos with DIY ideas....One guy welded rebar across the frame on his E450 based RV.
Another guy in England welded angle iron to both sides of the pipes at both ends of the converter.
There's also a product that looks like a thick belt that you adhere to the pipes across the cat and that gets wired to a siren under the hood. When you cut through the material the alarm goes off.
