Originally Posted by chachiboombatti
It is definitely correct, if you have access to alldata like I do you can see for yourself
So are you saying the connector shown is FOR the VSC, without some sort of mating connector VSC won't work?
My information says the clock spring and steering wheel with switches needs to be installed, connected and someone with dealer level PCM tweaking software needs to enable that system---beginning in 2005 it was 100% a function of the PCM.
This info ^^^ comes from checking printed EVTM copies of 2004 and 2005 when the VSC servos disappeared. Unless I've forgotten how to read EVTM's there is no connector(s) under the hood relating to VSC.
