Old 06-02-2020, 08:30 PM   #1
CDACamper's Avatar
Agile RIP Kit -what is this part for?
Just took delivery of an Agile RIP kit and going to tackle the install tomorrow. The install looks pretty straight forward but I am not sure on a couple of parts that were provided.
Anyone know what the two metal square shaped parts are for? Also, there are 4 bolts that are the same and 2 bolts that are the same (these 2 have a round stud end instead of a bolt head). Not sure what any of these bolts are for either (in the second picture you can see the 4 gold color bolts in the bag and the 2 black bolts above the U-bolts).
I added a few pictures of the full kit so anyone interested in this kit sees what is included.
I'll give Agile a call tomorrow but wondering if anyone knows what these are for.
20200602_183000.jpg   20200602_180957.jpg   20200602_180946.jpg   20200602_181041.jpg
______________________________
2001 E-350 V10 EB50 Penthouse
4.56 gears w/ARB Rear Locker
4X4 Quigley
Agile RIP
CDACamper is offline   Reply With Quote
Old 06-02-2020, 09:09 PM   #2
Square tubes are for dropping your sway bar, by adding some space between the sway bar brackets/bushings, and the frame. So the 4 long bolts should be for this as well.
The two round-head bolts look like spring-pack pins, to use after adding the leaves.
Old 06-03-2020, 09:57 PM   #3
CDACamper's Avatar
Thanks carringb, you were spot on with your guidance. The metal square tubes were to lower the sway bar. The holes lined up with the existing 2 bolts that holds the sway bar to the frame and the 4 bolts were a direct fit to bolt into the existing location. The bolts with pins were for the add a leafs. Thanks again for the help!
4X4 Quigley
Agile RIP
