I calculated my tire inflation from the Load and Inflation Tables. All the tire manufacturers publish these, and their numbers all match - regardless of brand. Only the tire size matters. Here is one from Goodyear:
http://octopup.org/img/car/tires/Goo...ruck-Tires.pdf
I weighed each corner of my van, while it was heavily loaded, and got the following values:
- Front L,R (lbs): 2100, 1950
- Rear L,R (lbs): 2800, 2650
When I look up my tire size (LT305/70R16) in the table, I see that for 65 MPH highway driving, I should be able to run 35 PSI front and 50 PSI rear. (I used to run 285/75R16, so I've highlighted those values as well.)
I usually round up to 40 PSI front and 55 PSI rear, just to have an extra margin of safety.
I also look at the tire temperature values from my TPMS. All four tires should show roughly the same temperature, even with different pressures - if they each have the correct pressure for their load.
On dirt logging roads, I run 25 PSI front, 35 PSI rear.
In deep soft sand, I go down to as low as 15 PSI.
-- Geoff
